Thread Topic: Bilstein install: quick help needed! Threaded
Date: 10-15-05 12:57
Subject: Bilstein install: quick help needed!
Hey, I've got the rear shocks all out, but I'm not sure how to put all the new washers/spacers back in the car.
Do I even need the little green spacer/bumper that was on the new shocks? Do I need two bushings, or only one? Flat washers or concave ones? The instructions don't really explain it at all. I tried searching, but couldn't find anything that explained it well.
Date: 10-16-05 06:19
From: jrhiddle in Altus, OK View user's profile Send e-mail
Subject: Try realoem.com - shows illustrated parts breakdown for the
whole car.
Date: 10-16-05 06:48
Subject: If your installing "SPORT" Bilsteins -
....DO NOT install the top rubber bump stop! this shock
has shorter travel - as per the instruction sheet included with the new shocks.
If your installing "H.D." shocks - YES, install the buffer stop.
also pack the top strut ball bearing with wheel bearing grease-
the concave washer is next to the under side of the ball bearing acting as the dirt seal - concave facing down -convex point up at the bearing
(nt)[/img]
 Filesize:  222.76 KB
 Viewed:  32 Time(s)
Date: 10-16-05 07:12
Subject: Re: Bilstein install: quick help needed!
For the rears you should leave the little green bump stop thingys. If they are HD's use the single bushing with concave washers... if they are SPORTS use the two black rubber bushings with flat washers.
Tighten them down until you just start to compress the rubber bushings and you're done. Sports will have a hex socket in the end of the shaft with a 17mm nylock nut.
HTH
Brian C
Date: 10-16-05 07:32
Subject: Bilsteins -SORRY ! thought he said FRONT ?!
...never thought anyone would have a problem installing the rears ?
