Date: 10-15-05 06:25
Subject: Re: Just some paint prep clear-up...
| WTA wrote: | | Ive decided that I will fully prep my car for paint, so that I can determine if everything is up to par, and to keep costs down as well. I just have a few questions maybe some of you could clear up. In terms of primer, should a certain shade be used? Im repainting the car Verona Red, so should I use one of the lighter colored primers? Also, when sanding the car down for the paint, what grit should be used? I probably have half a day's worth of patching and bondoing left, so Im just about ready on that front. Im also going to try and pull off as much stuff as I can. Any other tips you could give me would be greatly appreciated. |
you have your work cut out for you....1st, i'd remove everything from the car that can be removed, bumpers, mouldings, glass, etc
strip the old paint with 60 or 80 grit if sanding's your preference....i chemical strip, a lot less messy, imo
after it's stripped, clean, clean, clean it, then 2 or 3 good coats of epoxy primer. color is not important.....this keeps it from rusting and it's best to perform your bondo/body work over the epoxy...
red will cover a lighter colored final primer a heck of a lot better than darker ones...i'm painting one now and used the buff 2k (sandable filler) primer
if you're gonna spray the primers, why not try your hand at painting.....the pics below are my 1st maiden voyage into painting
Date: 10-15-05 10:59
| WTA wrote: | | Well the paint is just about a year old, so i dont think it will be that hard for it to come off. Where do you buy this chemical stripper? I might try that just so I dont have to sand it. Is it hard to use? |
if your paints good, i wouldn't strip it unless there are several old coats under it...i'd just sand it with 320 or 400, seal it with epoxy, block it with 2k filler then paint
chemical stripper can be bought for cheap at home depot or any hardware store....i spray it on, wait for it to lift, then scrape the old paint off with a plastic trowel
if you do chemical strip, key is to make sure when finished, that it's all washed off...otherwise, it can and probably would lift the paint from underneath
Date: 10-15-05 04:59
When I first painted the car, we just sanded down the original paint, so it is entirely possible a little is left over. The surface, as it is now, isn't all that bad. I will most likely just end up sanding it down. I also got a good start on the removal of exterior items; the airdam, flares, bumper, rain gutter trim, front turn signals and lights, rear light assemblies, bmw and 2002 emblems, and the two side grills were all removed today. As to the center "Kidney" grill, do any of you know off hand what size the nuts are that holds it on? I cant seem to get anything to work. Also, I was wondering how neccessary it is to get off the trim around the windows? I really don't want to get involved there because they are in relatively good shape. I may remove that chrome strip that is directly below the window, since I have done it before. As to the big chrome strip that runs around the middle of the car, I removed and patched that. Finally, would it be possible to rent a trailer of some kind to get it to the shop? I really don't feel like risking driving it there, even though it is a rather short trip. Thanks for all the help.
Will
Date: 10-15-05 05:09
another option is to take it to a professional blaster. It intails you removing everything, but they take the entire shell down to metal in about a day. Usually runs 3-500$
It would be worth it to me, just to save the hassle of all of the sanding.
TK
Date: 10-15-05 09:05
Subject: I did this, and
couple of things that helped me, bought a book from the local community college that has a program in auto body/painting. Also got a complete prep guide from the local auto paint store where I dropped some major $$$ on supplies. This was a three ring binder that explained everything to do to prep a car for painting using their products - Glasurit.
Even with careful prep I see some sanding scratches.
The ending prep has to be baby butt smooth, 600 grit typically, wet sanded.
One more item, DO NOT, I repeat DO NOT spray primer without proper protection, ESPECAILLY proper ventilation. This does NOT mean a dust mask. This stuff is REALLY bad, serious toxic, and not nice stuff.
I took my car to a local shop, sort of a MAACO independent and discussed what I wanted, slipped the guy a few extra $$, had them fine tune the work and it came out pretty damn good. Sent about $500 on supplies, $1100 at the shop.
