Date: 10-14-05 01:39 From: phocus Subject: Where does the 3/4" hose connected to the valve cover go?
Does it go right under the carb, @ the intake? The PO left one end lose the other plugged? I guess
Date: 10-14-05 01:45 From: Tom Winston Subject: it went in to the carb by the air cleaner but on many cars people
just put a breather filter on & leave it. Do whatever you like but older/tired motors have a habit of dumping some oil into the carb & it will make you go through air filters....
Date: 10-14-05 02:29 From: Curtis A. Ingraham Subject: It goes to the air filter housing, so that crankcase gasses...
get mixed with intake air and burned, rather than being dumped into the atmosphere. Be nice to your air. There is no performance or other advantage to venting it to the outside.
Date: 10-14-05 02:34 From: Tom Winston Subject: Webers don't have a way to attach that into the air cleaner.....(nt)
Date: 10-14-05 03:11 From: Russ Subject: Not hard to change that...
...judging by what a previous owner did on my car: 90-deg hose barb plumbed into the air cleaner.
Date: 10-14-05 03:22 From: Tom Winston Subject: If it makes you feel better.... mine goes right to the ground - BUT...
I don't have a heater box in the car at the moment so every time I stop at a light not only do I pollute the air but me, my lungs, my clothes, my fiance, etc. all get it...
Your car looks good. I'm in the process of building a new motor so in a few months it won't be an issue any longer - or actually it will still have just a breather because it will be a supercharged motor so no sucking going on there!
Date: 10-14-05 04:06 From: 02nd Marty Subject: venting it out does help, putting it back in lowers the octane of gas
so maybe that will save you from having to go up a grade and with these gas prices... besides the air+earth is so effed up by now theres not much you can do
Date: 10-14-05 04:38 From: Curtis A. Ingraham Subject: True, there is no fitting on the Weber, but many of the small...
air cleaner housings have a hole in the bottom for that fitting.
Date: 10-14-05 04:52 From: Mark B Subject: Thanks Marty, we'll suck it up for ya(nt)
