Thread Topic: Turn Signal problem..again.The last time I had an issue was Threaded
Date: 10-13-05 10:26
Subject: Turn Signal problem..again.The last time I had an issue was no signals
at all. Found out it was a faulty hazard switch. Got a new one, all is fine. I swapped my front lights for Euro turn signals recently also. Everything seemed fine until tonight when I need my lights to see. No turn signal functions at all! The rear ambers stay lit. But hazards work. I'm assuming it's the front Euros but can't see how. Don't have my old lights to test since I gave them away. Any ideas. thanks
Date: 10-14-05 05:53
Subject: Coupla things to check...
1. Make sure you connected the correct wire to the single filament bulb in your Euro front lights. One is for the parking lights, the other for the turn signals. US parking light assys use two filament bulbs, one for parking, one for turn signals.
2. Make sure the signals are grounding properly. they ground thru the mounting scrwes; chancy at best. Replacing existing screws with stainless steel will help. No ground=no front turn signals...
Date: 10-15-05 09:22
From: RayC911 in San Ramon, CA View user's profile Send e-mail
Subject: Re: Coupla things to check...
ok, check everything. Screws are new. did every combo possible with the wiring. Still no signals or hazards when the lights are turned on. ANy other suggestions??
Date: 10-15-05 10:25
From: cj in the BMW Sauber F1 car View user's profile Send e-mail
Did you wire them as turn signals or running lights? You probably did this but, did you insulate the end of the un-used wire? Did you change the blinker relay?
Cris
The rides!
www.cardomain.com/ride/792851
www.cardomain.com/ride/792793
Date: 10-15-05 10:26
From: SteveH in Central New Jersey View user's profile
The switch?
76 2002 40 DCOEx2 292 Shrick
1984 Mercedes-Benz 300D Turbo Diesel 240,000 miles
Date: 10-15-05 11:07
Cris
I'm using the U-haul Tap light so both wires are being used. The hazard switch is new. I would have changed the blinker relay too but everything is fine if i leave the headlights off. This sucks cause I can't take it out at night. ?????
