Thread Topic: how many of you actually torque stub axle nuts? Threaded
Date: 5-11-08 07:30
Subject: how many of you actually torque stub axle nuts?
i gotta be honest i just run em on with the impact. i dont have anything to register the 300lbs needed. i set the impact on the middle of 3 settings and let er rip. ive never had a problem but i stripped one nut recently. what are you guys doing???
email me unkorama@gmail.com
VISA/MC
Date: 5-11-08 07:48
Subject: torquing trick...
If the torque requirement is higher than your wrench, you can use your weight on a breaker bar by calculating how far from the nut you have to stand to generate the requisite torque.
For example, if you weigh 150 lbs and the required torque is 300 ft lbs, you must stand two feet from the nut being torqued.
Date: 5-11-08 08:09
From: Torg3 in Snohomish, WA View user's profile Send e-mail
Subject: Re: how many of you actually torque stub axle nuts?
Attached is how Boeing figures you to perform torques, especially with higher than normal limits using some math and torque adapters.
Hope it helps,
Torg
1976 2002, 2743935, "TIN CUP" (Polaris), near Seattle
 Filesize:  426.73 KB
 Viewed:  20 Time(s)
Date: 5-11-08 11:51
From: visionaut in Denver, Colorado View user's profile
Steve,
Yup, I use a torque wrench, and an extender and calc it. Tried by gut feel one time, and it was tight, but obviously wasn't tight enough, and it got loose and stripped.
Never did it the other way, and overtightened it. But gotta give the BMW engineers credit to figure how tight exactly to make that big F'n nut.
Tom
I'll drive... ;-)
v i s i o n a u t i k s
Date: 5-12-08 02:58
Subject: you actually torque stub axle nuts ?
if your nut is fuched, and the threads of the
stub axle compromised, and the splines
were runing loose, and your splines on both the
stub axle and hub are worn - you need all new
parts and start over again - or just redo it after
a few 100 or 1000 mileswith your method.
Date: 5-12-08 03:38
From: Ian in Rochester, NY View user's profile Send e-mail
I use the length of the bar to calculate the lbs delivered, and stand on the extender bar. Or, if I grovel appropriately, my friend's shop will let me borrow their 3/4" torque wrench.
Ian
'76 M2
Date: 5-12-08 06:32
Terry Sayther (from his website www.terrysaytherauto.com wrote:
Be sure to retighten the hub-nut as tight as you can after reassembling the drive flange---Really tight. Tighter than that
Amen.
ClayW
1976 Fjord 2002 Sunroof
Project Blog
Date: 5-12-08 08:51
Yup. Fat old me on 2' of extension= 400+ ft/lbs.
And 2 more things-
grease (or anti- seize) the nut pressure surface and threads well,
and then do it again after a few months.
Just because.
"Really tight. Tighter than that."
yup.
Date: 5-12-08 08:53
I use the same method Mike and others describe - weigh myself, do the math, and stand on the bar at the correct distance. If your weight is accurate, and you do the math properly, and stand at the proper distance, this method is every bit as good as using a Big Torque Wrench.
Torque is not complicated - force times distance. Torque wrenches make it easier and faster to do, but they are not required if you can do math.
-Karl
'73 '02 for club/vintage racing
'78 320/6 for parts for something or other
'83 320is for parts for '02
'87 325is for autocross
'91 325iX for traction
'95 M3 for power
'91 Jetta diesel for economy
