Post new topic    BMW 2002 FAQ Forum Index > Parts For Sale
Thread Topic: GB: 5 speed bracket and VW rear disc - closing 5/28/08 Flat
Date: 5-8-08 06:34
From: jakeb in Bay City, MI View user's profile Send e-mail
Subject: GB: 5 speed bracket and VW rear disc - closing 5/28/08
I have one of each cut and everything looks good. The 5 speed bracket matches up really nice with the one I made by hand
a while back and will be sending the new cut one to a FAQ memeber today to check it out on his 02 (mine has a m42 now....)
The 5 speed mount will bolt to the stock 02 mounting points and then swing around the trans. As you can see in the picture the holes are slotted a little bit to allow for some adjustment. The mount is made from 1/4" mild steel.
The price for one mount is $40
shipping:
$5 in the US, as many as you want
$9 to Canada, under 4lbs
$11 international, under 4lbs
VW brake brackets. You will get two of these, there will be a counter sunk hole to allow clearence for the caliper.
You use jetta rear calipers with the parking brake attachment and solid rabbit front rotors.
You need to have your rear hubs turned down to work with these.
You also need to grind a little bit off the trailing arm to allow one of the bolts to thread into the caliper. This allows for a tighter clearance for 13" wheels as well as full pad contact on the rotor.
Once I get my rear hubs back I will snap some pictures of the VW bracket on a trailing arm with everything bolted on.
$65 for one pair of brackets
shipping:
If you want multiple of one or the other, email me and I will give you a price break. If you want either one you can paypal to jake AT the guestroom dot NET.
I will let this buy go for 2 weeks and then start cutting. Some may get cut before that. I plan to get some additonal ones made so I will have them on hand.
If you have any questions feel free to email.
jake
70 2002 w/m42
91 318is w/m42
email for 02 and 02tii parts
                  Re: GB: 5 speed bracket and VW rear disc bracket..pics and p - H_Krix - 5-8-08 09:06
                        Re: GB: 5 speed bracket and VW rear disc bracket..pics and p - 70roundtail02 - 5-8-08 09:32
                              Re: GB: 5 speed bracket and VW rear disc bracket..pics and p - jakeb - 5-8-08 10:04
                                    Re: GB: 5 speed bracket and VW rear disc bracket..pics and p - maikelm11 - 5-9-08 06:32
                  Re: GB: 5 speed bracket and VW rear disc bracket..pics and p - ncoonen - 5-11-08 08:29
                        Re: GB: 5 speed bracket and VW rear disc bracket..pics and p - jakeb - 5-11-08 11:23
                              Re: GB: 5 speed bracket and VW rear disc bracket..pics and p - jakeb - 5-14-08 10:11
                                    Re: GB: 5 speed bracket and VW rear disc bracket..pics and p - Colin - 5-14-08 10:22
                                          Re: GB: 5 speed bracket and VW rear disc bracket..pics and p - ADVnut - 5-14-08 11:51
      Looks like 2002Haus' bracket - ClayW - 5-16-08 10:58
            Re: Looks like 2002Haus' bracket - H_Krix - 5-17-08 01:25
                  Re: Looks like 2002Haus' bracket - 70roundtail02 - 5-18-08 12:05
                        brackets - jakeb - 5-22-08 10:12
                              Re: brackets - jakeb - 5-25-08 01:31
                                    Re: brackets - Armond - 5-25-08 02:34
                                          Re: brackets - PBP - 5-25-08 08:00
                                    Re: brackets - devilspace - 5-25-08 10:23
            Re: GB: 5 speed bracket and VW rear disc - closing 5/28/08 - jakeb - 5-26-08 08:09
                  Re: GB: 5 speed bracket and VW rear disc - closing 5/28/08 - PBP - 5-28-08 10:25
                        Re: GB: 5 speed bracket and VW rear disc - closing 5/28/08 - jakeb - 5-28-08 02:58
                              Re: GB: 5 speed bracket and VW rear disc - closing 5/28/08 - Pinepig - 5-28-08 04:23
                                    Re: GB: 5 speed bracket and VW rear disc - closing 5/28/08 - jakeb - 5-28-08 06:41
                                          Re: GB: 5 speed bracket and VW rear disc - closing 5/28/08 - Pinepig - 5-28-08 06:52
                                    Re: GB: 5 speed bracket and VW rear disc - closing 5/28/08 - PBP - 6-1-08 05:20
                                          Re: GB: 5 speed bracket and VW rear disc - closing 5/28/08 - maikelm11 - 6-5-08 05:44
                                                Re: GB: 5 speed bracket and VW rear disc - closing 5/28/08 - PBP - 6-12-08 07:32
                                                      Re: GB: 5 speed bracket and VW rear disc - closing 5/28/08 - Justin_B - 6-16-08 02:59
                                                            Re: GB: 5 speed bracket and VW rear disc - closing 5/28/08 - ADVnut - 6-24-08 11:52
        Re: GB: 5 speed bracket and VW rear disc - closing 5/28/08 - jakeb - 6-24-08 04:08
        Re: GB: 5 speed bracket and VW rear disc - closing 5/28/08 - jakeb - 6-25-08 04:47
      Re: GB: 5 speed bracket and VW rear disc - closing 5/28/08 - aherna3@msn.com - 6-5-08 07:12
            Re: GB: 5 speed bracket and VW rear disc - closing 5/28/08 - jakeb - 7-6-08 08:59
                  Re: GB: 5 speed bracket and VW rear disc - closing 5/28/08 - Pinepig - 7-6-08 09:36
                  Re: GB: 5 speed bracket and VW rear disc - closing 5/28/08 - devilspace - 7-7-08 02:06
                        Re: GB: 5 speed bracket and VW rear disc - closing 5/28/08 - jakeb - 7-7-08 04:01
                              Re: GB: 5 speed bracket and VW rear disc - closing 5/28/08 - 70roundtail02 - 7-7-08 08:33
                                    Re: GB: 5 speed bracket and VW rear disc - closing 5/28/08 - jakeb - 7-8-08 05:43
            Re: GB: 5 speed bracket and VW rear disc - closing 5/28/08 - PBP - 7-13-08 03:28
                  Re: GB: 5 speed bracket and VW rear disc - closing 5/28/08 - jakeb - 7-13-08 03:56
                        Re: GB: 5 speed bracket and VW rear disc - closing 5/28/08 - skipsfcr - 7-15-08 08:07
                              Re: GB: 5 speed bracket and VW rear disc - closing 5/28/08 - Colin - 7-15-08 08:52
Post new topic    BMW 2002 FAQ Forum Index > Parts For Sale Flat
