Thread Topic: Windshield install made easy. Flat
Date: 8-26-06 10:53
From: DukeRimmer in santa cruz View user's profile Send e-mail
Subject: Windshield install made easy.
Removal
Step1; Remove wipers.
Step2; If the rubber shows no trace of cracking, and is not glued down, insert a small screw driver, without scratching the paint, lift up to test for rubber softness and stretch. If your car is a beater like mine and the rubber is soft you can save it by pushing it out from inside the car. Using two very worn screw drivers pull the inner lip of the seal down at the top and push it forward past edge of the car body. Holding that tiny bit of seal past the metal edge, push out another ¼ inch with another worn screw driver. Repeat several times working the top out evenly. Go around both corners and down both sides evenly. Tilt forward and rock until the assembly can be lifted away.
You’ll probably need to make the screw drivers because they need to have round corners and no sharp edges. If they still work for screws, they’re too sharp. Please do not scratch paint or tear headliners.
OR
Step2; Insert utility knife between glass and seal, cut to the lock strip at the top and both sides. Cut til inner rubber and lock strip fall away. You'll then see the edge of glass. Push glass out from inside.
Step 3; Clean under seal area without scratching paint. Attach headliner, if loose, with contact cement such as wurth rubber glue.
Installation
Step1; With the glass face down on a soft bench, stretch the rubber over the glass. Turn over and install the lock strip. Leave the ends of the lock strip protruding from the center of the bottom of the seal.
Step2; Insert rope so it exits from the center of the bottom of seal. Bundle the excess ends and tape them to the inside of glass. Tape the top of seal to glass with two strips 2 feet apart. Lube the rear most lip of the seal both inside and out.
Step3; Put glass/seal assembly in place using a volunteer, if you must, then send your helpers home. Step to the front of the car and see that the lower corners are centered.
Step4; Standing in the doorway, push down on the upper part of assembly with one hand while pulling rope with the other. Pull rope 10”-12” and repeat from the other side. Step to front of car and see that the lower corners are centered. Use the same technique to pull another 12” on each side and check for centering from front of car. While pushing down firmly on top, rope in the lower corners and check for centering from front of car.
Step5; You are now finished pushing and will slap the glass into place with glancing blows in the direction you want the glass to move (mostly down). In the end you will have a pleasant little tingle in both palms and all fingers. Standing in front of the open door, slap the glass in with one hand while pulling the rope half way up one side with the other. Repeat from the other side. The lower corners should now look normal from the front of car, and the seal must look seated at the dash as seen from inside the car. If it looks wrong at the dash or if the lower corners are not perfectly centered, start over.
Step6; Remove the tape from the top. Slap and rope in one upper corner. The lower portion, and one side of the seal should now look normal from inside the car. Slap and pull in the rest of the seal. See that the inside lip of seal looks normal, and that the outside of upper corners are not bulging. If there is bulging, or the inner lip is not seated completely, start over, making sure you start by fully seating and centering the bottom of the seal.
Step7; Cut the lock strip and install the joint cover. Leave plenty of lock strip under the cover to allow for shrinkage.
Photos
Pic #187; Removal.
Pic #137; Worlds most convenient contact adhesive.
Pic #138; I use wire pulling lube. The tool on the left is a lock strip installer purchased when I thought the strip was installed last. It hasn’t been used since 1984. At the center is my nylon rope with section of radio antennae for easy installation. It allows you to push the rope in very quickly. The tool at the right is a wiper remover.
'02 stuff for sale at; http://pageproducer.arczip.com/mdyjc/index.html
      one addition - TobyB - 8-27-06 10:53
      Re: Windshield install made easy. - robspeed - 8-27-06 11:12
            Re: Windshield install made easy. - DukeRimmer - 8-27-06 07:29
      Re: Windshield install made easy. - JK - 9-4-08 10:24
