Excellent running, sounding, and stopping 02. Car tracks true down the road, has good power, and handles superb. Needs very little to be top notch. Great driver "as is" with extensive history & documentation. Formerly owned by Creighton Demarest (c.d.diesel) from this board. This was the test car for the CD prescription weber 32/26 set up.
Email
ccrelan@aol.com for pics.
Here is the work done from 2001.
* Supersprint header and full Ansa sport exhaust
* Bilstein Sport Shocks
* H&R lowering springs
* Tucked front bumper
* Upgraded headlights
* camber plates
* stock front & rear sway bars w/ urethane bushings and links
* front strut housings
* front brake calipers, rotors, and pads
* steel braided brake hoses
* gas tank
* front wheel bearings
* all tie rods, center link, and idler arm w/ bearings
* motor mounts & trans mounts
* guibos x 2
* water pump
* heater valve
* fuel pump
* fan
* recored radiator
* all relays
* clutch, clutch master, slave, hoses w/ busings, and clutch lever in trans
* oil pump, rear main seal, and pan gasket
* timing chain tensioner
* trans shifter platform and shifter bushings
* tail light lenses with seals
* speedometer (approx 120k overall)
* speedo drive gear
* front windshield w/ seal
* back glass seal
* battery relocation
* front and rear strut braces
* MUDFLAPS!
Work in the last two years:
* 320i alternator
* head gasket
* black carpet
* hella fog lights set up to work with dash pull switch and relays
* parker performance console
* modern cd player w/ infinity speakers mounted under rear seats
* non ripped 320i recaros
* BWA steering wheel
* E30 basket weave rims
* full tune up prior to driving to Lime Rock this weekend
* driver side frame rail and complete drivers side floor pan done by Sports Car Restoration
* rear brake drums
* rain gutters
* differential mount
