winstont AT direxionfunds DOT com
Ash,
same as the 2002 but with a little more trim. You have to take off the steering wheel - do you have an airbag wheel (i hope not)... pop off the roundel, remove the wheel, there will be a few little phillips screws up under the top piece of trim, remove that and the outer trim cover will come out. I think (its been a while) that you have to remove a piece of trim between the gauge cluster and steering wheel column - that is held in with a few nuts behind like the cluster in an 02 is held in.
re-reading i'm seeing that this is a pretty piss-poor description... you could go to a junkyard and tear one out to learn how???
Email me if you have questions - its easy... if you can do brakes on an 02 you can remove the cluster on a n e30.
Battery you are looking for is behind the cluster IIRC.
BMW-Yachtsport
'07 Accord DD
