| granth wrote: |
So how to keep this stuff leaking? Normal 90wt gear oil in trans was fine, I put this stuff in and it leaks out over time. Got the bolts on the trans cone tight any other ideas?
thanks
grant |
If you are using 75w90, it is a multi-weight that is less viscous than a straight 90 weight. Either pull your tranny and replace the seals, or get used to it. You might also try using a heavier weight oil, like redline 80w140 or similar weights available from Swepco, Royal Purple, Mobil, etc. Or, just try one of the 75w90 gear lubes available from the other brands and see if you get less leakage.
Chris B.
'73 ex-Malaga
