Thread Topic: 73 2002 with mechanical advance type distributor Threaded
Date: 7-23-08 11:04
Subject: 73 2002 with mechanical advance type distributor
Hi folks,
The previous owner replaced the stock distributor with one from a ti engine (0231 151 008). It has a weber 32/36 carb.
How is it's reliability and ease of maintenance (set engine timing) compared to the vacuum type?
I am contemplating going back to the stock distributor but I want to find out if I can set this one correctly before I make a decision.
Thanks in advance,
Jan
73 inka
Date: 7-24-08 12:16
From: Chris_B in Scotts Valley, CA View user's profile Send e-mail
Subject: Re: 73 2002 with mechanical advance type distributor
jan1968 wrote:
Hi folks,
Thanks in advance,
Jan
If you have a setup (such as you do) that can drive a vacuum advance, there are significant improvements in light throttle, light load driveability and fuel economy to be had. The procedure for setting timing is pretty much the same (after you disable the vacuum advance...). The vacuum advance unit is one more bit that can fail, but there are many 02s benefiting from this technology (with, collectively, a gazillion miles on the mechanisms).
Chris B.
'73 ex-Malaga
Date: 7-24-08 03:30
Subject: I believe the 73s had a vacumm retard distributor
the distributor caused a reduced idle to "reduce" emissions to pass US standards.
1972 2000tii Touring
1972 2002tii with A4 system
1972 2002tii found a motor
16' Mad River
Date: 7-24-08 05:07
Subject: Don't believe vacumm retard distributors were fitted until
either 1974 or '75...I know the 73's don't have 'em--my 73's dizzy is original and only has the advance unit.
Date: 7-24-08 10:19
Subject: Right again Mike - it was 74 (nt)
16' Mad River
