Thread Topic: Jack Stands - Front Placement Threaded
Date: 7-19-08 07:06
Subject: Jack Stands - Front Placement
I did a search and saw some threads on putting jack stands under the rear, but wanted to ask about the front. The features that I would call frame rails are too wide for my stand; I like a point that settles into the head of the stand.
Ahead of that, I see some points that might work, but they are all connected (in some way, shape or form) to the front suspension, and I don't want to set the car on something that will botch my alignment or suspension. You never know when you'll pick THE weak point, so I thought I would ask.
Donations can be made to the Derelict Bavarian Fund.
Date: 7-19-08 09:56
Subject: Re: Jack Stands - Front Placement
I made wide (4") flat clips, welded them to the tops of the stands
and put 'em under the front inner fender connectors
(what you'd call the 'frame rails')
The front subframe itself is also stout enough to take point loading.
None of the front suspension really is...
nor is the rocker panel.
Date: 7-19-08 09:58
From: John_in_VA in Leesburg, VA View user's profile Send e-mail
Subject: There are several points to use...
but I place them under the "pipe" (#10) where the control arm attaches to the subframe.
[/img]
John in VA
'74 tii "Juanita"
'85 325e "Ol' Blue"
'86 535i "M-POSSTR"
'00 328i "Fern"
Date: 7-19-08 10:19
TobyB wrote:
I made wide (4") flat clips, welded them to the tops of the stands and put 'em under the front inner fender connectors (what you'd call the 'frame rails')
Good idea. Thanks for that.
That was one of the areas that I was considering.
Date: 7-19-08 01:25
From: 2002Targa in Kodiak, AK View user's profile Send e-mail
Something to consider if you use the frame rails. Jackstands here stress the car. Try jacking it here for a bit with the stands and check how differently the doors close. U usually turn the flat part of the stand sideways and put it by the mentioned #10 bolt on the subframe. That way all the stress is where it would normally be while resting on the wheels.
TK
Life's a garden baby, dig it.
My web album
75 Fjord
73 RHD Targa
Date: 7-19-08 01:27
Subject: Re: There are several points to use...
[quote="John_in_VA"]but I place them under the "pipe" (#10) where the control arm attaches to the subframe.
I use the same area..basically the 'pipe' would be the area where the bolt runs through that holds the control arm to subframe. That's a very sturdy place..I've never had a problem placing my jack stands there.
Jeremy
'72 2002Tii - Track Car
Date: 7-19-08 02:05
From: jgerock in Alexandria, VA View user's profile Send e-mail
I've been using the frame rails (after wrapping the top jackstand "head" with duct tape to provide a little cushion), but next time I'll try the round rods (# 10).
BMWCCA # 381868
73tii "Celeste" # 2764081
71 VW Cal-look Bug
Date: 7-19-08 02:30
From: peteinjp in Toyama, Japan View user's profile
I place a 2x4 or stouter piece of wood along the length of the frame rail and put the stands under that. I find that having the stands under the subframe often gets in the way of the work I need to do.
On a side not one of these days I'll get around to making a beam that uses the stock jacking points aka bolts number 10. There is a diagram for it in the factory manual.
Date: 7-19-08 05:36
what about a 2 post hoist, where would the lift points be?
zee wrote:
holy negative camber batman!!!
tii pistons, 293, 40mm DCOE's, sump baffle approx 150hp
