| BLUNT wrote: |
| you have to have some pretty damed good bodywork to pull off black and make it look good. |
yep...that's my big hesitation about doing this one in black...black will accentuate every flaw...fortunately, the filler work is gonna be minimal on the large, flat panels...
for some reason..whoever worked on this car in the past had an obsession with bondo...there was bondo all over the car that didn't need to be there as there was no body damage underneath just heavy sanding marks...
the filler seen on the doors and trunk is only a skim coat to fill some deep scratches formerly made by heavy sandpaper or a grinder....it's easier to skim them than to grind away more metal
the only spot that needs or needed substantial work was the nose at the front fender area and there's one spot on the drivers quarter that will require a small amount of filler to fill the dimples i made hammering out a small dent
i'm still undecided on color...i have both black and green and might spray the door and the hood in green and the door and trunk, which i used filler on then look at them a while before shooting the entire car....i'm in love with oz_tom 's black beauty
if the black pieces past muster, i'm inclined to go black and use the green on my 72
armond....what about a green/black 2-tone.....like a 54 buick paint scheme
