Thread Topic: Schwarz 73 Tii resto updated 7/16/08 Threaded
Date: 11-8-07 10:45
From: scestes in Bay Area, CA View user's profile Send e-mail
Subject: Re: Schwarz 73 Tii resto
Yea, I think when I go this route. engine and tranny are coming out, and going in as one piece. I think there is far less headache.
-=Scott=-
My Short Bus
1971 2002 - "William Grover-Williams" - Track/Weekend Car VIN 2579197
1998 740iL E38 - "Blau" - Daily Driver
http://gallery.xfiler.com
Date: 11-22-07 12:07
From: kris in Toronto View user's profile Send e-mail
Recent updates...
POR15 applied to the spare tire well and rear shock towers as a preventative measure, Chassis Coat to follow for a nice clean look
Also have my new Oydessy PC925 battery for the trunk, just looking at mounting options
Prepping the underbody for a bit of POR15 and then Wurth High Build underbody spray
In 2 weeks, weather permitting, the POR15 will be worn off my hands and I'll be installing the driveshaft and exhaust.
Pics to follow
73 Tii
Date: 11-23-07 12:01
Keep up the good work Kris. I look forward to going for a ride this spring:)
What wheels have you decided to go with?
I saw you have your Alpinas for sale.
Date: 11-23-07 08:41
I'm looking fwd to driving it with you guys.
I got a set of Mahle BBS 13x6 which should clear without rolling the fenders. Kind of like what Dwight has on his Tii.
73 Tii
Date: 12-4-07 10:06
Well the Mahle wheels were short lived...they wouldn't clear my E12 5 series calipers and vented rotors. I've decided to go to an E30 15" Alpina or 15" BBS RS or RZ or ??..I want a light, strong wheel that looks good on an 02...I like the Alpina Classics on CJ's car as an example.
Right now I am still buried in undercoating / POR 15 work. I feel like I'm working out of order, like all this should have been done when the car was apart, but hindsight is 20:20. I spent a few hours removing the rear brake lines that run from the splitter to the flex lines in the subframe...apparently it's hard to get these off with the subframe on the car. I feel like I'm slowly going down the road of trying to make the bottom of the car as nice as some of the examples on this board. With this in mind, I'm thinking about dropping the rear subframe to repaint it. The PO did refurbish it with all new urethane and he painted it, but his paint is peeling off on touch as he obviously didn't prep the surface well (no surprise considering other evidence of his attention to detail). So I've dropped any immediate plans to get the car running right away. I'm really enjoying the -10 C / 20F weather on the floor of my garage.
Coming up
Rear subframe?
Wheel wells, POR + chassis coat
Floor - Wurth undercoating
73 Tii
More POR & undercoating to come
 Filesize:  185.5 KB
 Viewed:  41 Time(s)
POR 15, it smells awful and it works
 Filesize:  165.28 KB
 Viewed:  35 Time(s)
 Filesize:  120.19 KB
 Viewed:  30 Time(s)
Trunk POR15 and chassis coat
 Filesize:  139.68 KB
 Viewed:  41 Time(s)
Date: 12-5-07 06:16
Too bad about the wheels not fitting. Can you post a picture of them if you still have them? Do you want to sell them? I have stock brakes so no fit problem.
Good thing about having a black car is everything above and below will match when you are done.
Yes, I am keeping an eye on your restoration :)
Date: 12-5-07 08:20
Wheels don't fit, paint flaking off the subframe, POR-15 everywhere... This is starting to sound like my build!
I wore a charcoal respirator when working with the POR-15 and the Herculiner afterwards. The Herculiner was particularly bad, and I know I would have passed out had it not been for wearing a mask. Your work looks like its coming along well though, good job!
Any plans on taking the tank out? I know a lot of rust was hiding around the cork gasket on mine. You should probably pop yours out to take a look, since you're going through all this trouble.
Date: 12-5-07 08:29
Thanks for the kind words, you know your pictures are the reason I'm under my car this winter!
I've been wearing a respirator as well. I did have the tank out and had it repaired (as it had a few pinholes). Is that cork gasket NLA?
73 Tii
Date: 12-9-07 03:18
From: ray_koke in Tianjin View user's profile Send e-mail
Hope it's NLA. ;-)
Use some closed cell foam or equivalent (and not something that'll hold moisture!).
Cheers,
Ray
'73 ///M2 2.5
'84 ///M635CSi
Date: 12-29-07 11:34
Lots of work has happened in the last few weeks...
Gloss coat in trunk
Rear subframe out and broken down for stripping & painting
Tii fuel pump out
The subframe is in good shape, but the paint job from the PO was terrible; it was falling off into my hands when I took the subframe down. On the positive side, all the hardware is in good shape. I'm taking the opportunity to upgrade the rear brakes from 320i drums to a set of disc brakes from Aardvarc (along with a set of BBS RM's)
Tonight I am proud to say marked the last time I had to REMOVE something from the car (fuel pump). As of now, I am officially on the way to putting it back together!!
Next up
Clean moil off the underbody
POR15 rest of underbody
Wurth high build underbody spray
repaint / reassemble subframe with disc brakes
Pics to follow/
73 Tii
Date: 1-11-08 03:43
Some subframe in progress pics...I have a few really nice POR15 tattoos right now including one on the top of my head
73 Tii
He painted it, but didn't prep it.
 Filesize:  233.99 KB
 Viewed:  28 Time(s)
much better, 3 hrs later
 Filesize:  307.82 KB
 Viewed:  21 Time(s)
cleaned up
 Filesize:  290.11 KB
 Viewed:  19 Time(s)
Date: 1-11-08 03:45
I've also cleaned the moil off the underbody...the dirtiest job so far - I came out looking like a coal miner afterwards. Definatley a job for a respirator (which I wore) as I ground the moil off with a soft wire brush. One coat of POR15 is on, one more tonight and then undercoating. The nice thing is the weather is cooperating so I can feel my fingers.
Also got in shiite for spilling POR15 all over the floor of the garage - told my wife I will be finishing the floor in the spring.
73 Tii
 Filesize:  214.97 KB
 Viewed:  15 Time(s)
Date: 1-11-08 05:30
really nice work kris. youll be so glad you arent cutting corners when it all gets back together. there were times i wanted to take shortcuts and im really glad i havent to this point
email me unkorama@gmail.com
VISA/MC
Date: 2-8-08 10:33
Well my update is that there is a lot of snow up here, it's been cold, and I've been sick with the flu...but I did receive some nice packages in the mail:
- All new subframe hardware from Blunt
-15" BBS RM 1/2" front lip. 1" rear from Dave Varco
-rear disc brake kit from Dave Varco
If anyone has been wondering about the quality of the stuff from Dave, it's amazing, and he's very helpful.
As it stands, the subframe is painted with POR and Chassis Coat, one trailing arm is stripped, the other hopefully this weekend. Plus my final coat of POR on the underbody should go on as well.
Pics to follow this weekend.
73 Tii
Date: 2-9-08 10:07
Nice Job Kris. Keep up the great work!
73 Tii. My Daily driver
Volvo V70 Turbo,Wagon
Ad Deum Per Fidem Mores Culturam
Date: 2-11-08 09:36
I take back what I said about being finished disassembling...my stub axles are bad, the splines are rounded. So, more parts on order and I've been reading up on "motivating" the stub axles out of the trailing arms for replacement.
The more you dig, the more you find, the more you dig...
Pics to follow
73 Tii
Date: 2-11-08 09:42
I did the same thing in our garage. also got some on my arms. I couldnt see my clients for weeks.
Date: 3-2-08 08:18
Here's some recent stuff
Trailing arms prepped for POR15
First coat
New wheels, BBS RM 15x7 1/2" front lip, 1" rear lip polished from Dave Varco
Aardvarc Big brake kit calipers etc
Once I get a few more coats on the subframe, I can put it back together and mount the big brake kit etc.
73 Tii
Date: 4-14-08 02:13
Finally had some time and decent weather to get my rear subframe back together. Did two layers of POR15 and two layers of POR Blackcoat. Bushings are IE, Suspension Techniques swaybar, and lots of shiny new OEM hardware incuding spindles. In the process of putting on an Aardvarc big disk brake kit, you can see the adapter brackets and the cadmium plated hubs. The brake lines were bent to face straight back to mate with the Aardvarc calipers which bolt towards the bottom.
Working on the Tii pump and fuel lines, then the subframe will go back in.
73 Tii
Date: 4-14-08 02:19
Here are some pics of my work on the fuel pump, cannister and underbody. Will be keeping the pump and cannister as a spare and buying new, to make sure my new motor is fed properly. Next up is to install the new fuel pum[p & cannister, along with plumbing the 12x18 fuel line from the tank to the pump (which is not supposed to be any fun at all...)
got rid of the old paint
Rattle can works well sometimes
Wurth undercoating on top of POR15 on the underbody
Lots of Wurth in the wells with POR15 underneath
73 Tii
Date: 4-14-08 09:44
You've come a long way Kris! Those RM's will suit the car down to the ground... bad pun i know, but its true!
Date: 5-7-08 07:31
From: cj in the BMW Sauber F1 car View user's profile Send e-mail
Kris-
Did you ever find an antenna. If not, I have a decent used one that you may be able to clean up.
It has the big rectangular base.
Cris
The rides!
www.cardomain.com/ride/792851
www.cardomain.com/ride/792793
Date: 5-8-08 09:11
Do you have any other shots of that aardvarc rear disk kit? I'm trying to figure out if thats a mod I want to do later on.
Do you have to install a bias valve at all?
Date: 5-8-08 08:22
Just let me know what you want and I'll take the pics. According to Dave Varco, the bias valve is not necessary. I'm running big brakes up front as well. I was impressed with the quality of the kit and instructions.
73 Tii
Date: 5-24-08 03:34
Recent updates...
New Tii fuel pump and cannister in; the 12 x 18 fuel line was a breeze after I greased the fuel line and rammed 'er in.
Rear Subframe reinstalled and Aardvarc bike brake kit underway
VW rear brakes a la Aardvarc, nice kit but a lot of Dremel work on the trailing arm and caliper bracket to make it fit
Front brake resto underway (Ireland Tii front big brake kit being installed)
BBS RM, now with disc brakes
Up next
finish brakes. bleed system
POR 15 in front wheel wells
install tranny (2002 Haus hardware kit on the way! Thanks Rob!)
driveline
install new front engine harness
a bunch of other stuff and start the car!
73 Tii
Date: 6-5-08 08:43
Recent pics
front wells with POR15 (front suspension/subframe to be rebuilt this winter)
Ireland header, back from Jet Coating
Trunk with Odyessy battery & Ebay tray
73 Tii
Date: 7-16-08 11:40
2002 Haus 5 speed kit installed - great build quality and instructions and Rob is a real help when you're doing something wrong!
73 Tii
Date: 8-10-08 08:19
Engine bay almost complete! Need to replace the hood insulation and a few other small jobs.
Finished the wiring thanks the Steve and Keith who were my email saviors with advice for an admitted wiring noob. Made sure I had good grounds for the trunk, block and alternator and it started!
Needs some fine tuning, but nothing caught on fire!!
73 Tii
Date: 9-30-08 09:07
It drives! Still needs lots of trim work, but I'm on the road (until it snows in a month anyway).
73 Tii
Date: 10-1-08 05:32
real nice kris. i missed the detailed engine and undercarriage shots. beautiful work.
VISA/MC
Goto page Previous  1, 2, 3
Page 3 of 3
