Thread Topic: project 2020 Threaded
Date: 6-30-08 09:49
Subject: project 2020
Here are some pics of my new project. Please be patient I am moving along very slow. The list of things done so far isn't very long but here they are:
Ireland stage 2 springs (soon to have sport struts)
15 X 8 wheels 0 offset
205/50/15 rubber on corners
Right now I am working on getting the sr20det to fit. I have almost finished the front crossmember and am working on the trans crossmember. Things are moving along pretting slow but I do know that I have to run a topmount turbo probably a gt30r, and a wilwood pedal assembly. I will update this post with many more pictures and info soon
 Filesize:  52.98 KB
 Viewed:  76 Time(s)
 Filesize:  56.42 KB
 Viewed:  59 Time(s)
 Filesize:  75.85 KB
 Viewed:  60 Time(s)
 Filesize:  54.45 KB
 Viewed:  44 Time(s)
Date: 6-30-08 11:42
Subject: Re: project 2020
Holy moly you'll have alot of power. Should be gobs of fun though!
What diff are you going to use?
Date: 7-1-08 06:32
I have a s13 240sx rear diff and sub frame laying around that I am going to use.
Date: 7-1-08 02:59
From: CamB in Auckland, New Zealand View user's profile
Are those the Sportmax wheels?
Any more pics of how they fit and whether they'll rub? It looks like the front arches needed a fair amount of work...
Thanks!
2002tii race car
Date: 7-1-08 08:29
They are the sportmax wheels. You need to run a hubcentric spacer to make them fit properly. They will definitely hit the firewall and very little in the front where the fender meets the lower valence.
 Filesize:  70.58 KB
 Viewed:  31 Time(s)
 Filesize:  66.77 KB
 Viewed:  30 Time(s)
 Filesize:  66.32 KB
 Viewed:  30 Time(s)
 Filesize:  80.15 KB
 Viewed:  31 Time(s)
 Filesize:  75.85 KB
 Viewed:  58 Time(s)
Date: 7-8-08 06:13
How did you get the exact measurements on how much to cut off the metal?
Cheers
Sim
Date: 7-11-08 06:38
I didn't use any exact measurement. I knew I wanted at least an inch or inch and a half behind the wheel. As you can see in the picture from tire to firewall there was no clearance, but it just started to rub at full lock. I drew a line free hand right where the tire would rub and then drew the rest of the line so it looked appealing and somewhat stock. I cut it out and used the piece to mark the other side so it was the same. I have some metalfab experience, few chopped tops, working on a pretty custom 63 nova, 31 ford truck etc. Sometimes your eye is the best judge for how it should look when its finished
Date: 7-31-08 08:56
On the cut out for the wheel clearance, what did it look like under the piece you cut out? Was there mutiple panels that came together? I really wanted to clearance my car there but was afraid I'd be weekening the unibody?
Date: 8-19-08 08:13
sorry for the slow response. There is only the quarter panel and the outer wheel house. I cut the quarter panel out where I needed to, then pie cut the wheel house so it would roll out and meet up with the quarter panel. I then welded the whole thing back up. I don't think there is any significant loss of structure if any when done properly. I will try and post more pictures of those steps.
