Thread Topic: Strange behaviour - help needed! Threaded
Date: 7-9-08 09:33
Subject: Strange behaviour - help needed!
Hello,
I am experiencing some trouble with my 2002 '71, and I am wondering if some one out there could give some hints on what to do.
Symptoms: When the engine gets warm (after driving for maybe 15 min) the car starts choking itself, almost as if it is getting to much gasoline. It has an almost normal idle, but when I release the cluth and give it some more gas it starts to stutter. I then push the cluth all the way down and rev the engine - this clears the stuttering, but when I try to drive away again the same problem occurs. This appears mostly in the 1st and 2nd gear, and isn't that noticible in the 3rd and 4th, although it isn't running very smooth at high speeds either.
When the car is cold I have none of these problems - it starts fine and idles great and there is no problem driving in the city, i.e. until the engine gets warm.
Changes preceding the symptoms: New oil-, air- and fuelfilters plus a new Hot Spark installation (electronic ignition ).
Free speculation: Could it be the Hot Spark installation? I would think that either the ignition works (which it does when cold) or it doesn't. Please correct me if I am wrong.
Could it be the new inline fuel filter that behaves strangely when the engine gets warm? To me this sounds very strange, but then again you would know better than I.
Thank you in advance!
/Mikael
Date: 7-9-08 09:46
Subject: The easy answers are...
Is the choke stuck?
Might you have dislodged some dirt in the fuel line that's now clogging the idle jet?
I'm not sure what your new ignition system is, but is there any chance the timing or dwell are off? Is the condenser (if you still use one) attached tightly (for a good ground)?
David Roach
"Molly" (Inka 1973 2002)
"Nick" (Schwartz 2004 330xi)
Date: 7-9-08 09:53
Subject: Re: The easy answers are...
Thank you for a quick reply!
No the choke moves as it should.
The filter looks clean, and it idles fine when the engine still is "cold". It's only when driving the car for about 15 min that the problems starts.
The ignition system is Hot Spark (http://www.hot-spark.com/ - similar to Pertronix I suppose. No the condenser is replaced with the Hot Spark system.
Date: 7-9-08 10:05
From: themoose in Scottsdale, AZ View user's profile
Check your plug wires as well and make sure they're getting full connection. Jiggle them around after it's warmed up and see if the idle changes at all.
'74 2002 (undergoing Megasquirt conversion!)
Date: 7-9-08 11:06
From: Napes in Nogales, AZ View user's profile Send e-mail
I'd visually verify that the choke is indeed fully open after the engine warms up. It sorta sounds like the choke butterflies are not opening all the way after warm-up.
Bob Napier
Date: 7-9-08 11:12
Subject: Are the symptoms accompained by black smoke from the
tailpipe? If so, this sounds like it could be an overly rich condition once the engine's warmed up. As David said, check your choke. I presume you have a 1 bbl Solex carb since your car's a '71. Keep in mind that the choke on these carbs operates both the strangler valve at the top of the carb's air horn, and also activates a linkage that increases the idle speed.
With the choke knob fully pushed in, the strangler valve should be vertical in the carb's air horn, and the idle speed should be back to normal. Have someone pull the choke knob in and out while you observe how the linkage works and you'll see what I mean.
My other suspect would be trash in the idle jet. It actually provides fuel flow up to about 2000-2500 rpm, so a partially plugged one would affect engine performance well above idle speed.
Other than your disturbing ignition timing while installing the new system, I can't think of any of the recent work you described as causative factors.
Date: 7-9-08 12:37
Subject: Re: Are the symptoms accompained by black smoke from the
Mike is always right - except when he is given bad information.
Why don't you confirm the type of carburetor you are using including whether the choke is manual or water activated. IF you had gunk in the idle jet or even have an idle jet solenoid that has been disconnected or not working (accessible from the side of the carburetor) it may be that you are really running off of the fast idle cam and the choke. When the engine warms up or when you open the choke the idle circuit is still plugged or handicapped and this would account for a crappy idle and poor low speed running.
Brakes that are dragging, bad cracked motor mounts, bad transmission mount and/or a worn or maladjusted clutch might account for or magnify a poor running engine. The fact that you claim everything runs fine when cold would seem to vitiate this possibility.
Date: 7-9-08 12:39
Mike, Bob, themoose and Daniel - thank you for your suggestions.
I will look into them tomorrow and get back to you with the results.
/Mikael
Date: 7-9-08 02:27
From: Clydeg in Little Rock, AR View user's profile
Subject: Re: Strange behaviour - help needed!
Just out of curiosity - did you replace the ignition coil with a coil that has an internal resistor (Bosch Blue coil, for instance) and not bypass the external resistor? The combination of a coil with an internal resistor and an inline external resistor could reduce the voltage to your distributor too much.
'73 2002 "Gretta"
'70/75 2002 "Wilhelm" aka "Slick Willie"
'74 widebody with schnitzer flares "Brigette"
'75 parts car
BMW CCA #19280
The difference between Genius and stupidity is that there is a limit to genius - Albert Einstein
Date: 7-12-08 11:28
No I haven't removed the resistor. Do you think that I should? I have the setup that can be seen below.
How can I measure the strength of the spark? Would the spark be weakend as the engine warms up?
I forgot to mention that the car has also "back-fired" once after turning of the ignition.
I haven't had a chance to inspect the carburator and the choke yet, but I will on Monday. Happy Weekend!
 Filesize:  55.22 KB
 Viewed:  4 Time(s)
Date: 7-13-08 01:09
that appears to be a Bosch Blue Coil (internal resistor). The purpose of the resistor is to let 12 volts through the distributor for easier starting, then (as the resistor heats up after the car has been running a bit) to reduce the voltage to 6 volts for point longevity. the voltage reduction is probably unnecessary in any electronic ignition and will almost certainly adversely affect an electrical ignition with an optical trigger (remember what a flashlight beam looks like when the batteries are almost shot).
imho - bypass the external resistor and see how it runs. Cd or Skip or Mike (or any professional mechanics, EEs or long time 2002 owners may have better information - I have only owned, driven, and worked on 2002s since 1974) may have better information.
'73 2002 "Gretta"
'75 parts car
BMW CCA #19280
Date: 7-15-08 12:58
Mike, Bob, themoose, Daniel, Tiko and Clydeg!
Once again for all your insightful suggestions.
Having checked the choke (manual) and the jets on the Solex 36-40 PDSI everything checked out and was functional. The resistor was also removed as suggested but didn't improve performance at all.
Unable to figure out the fault, I had a mechanic remove the new electrical ignition, and reinstall the old pointers and condenser, and Whola! The engine works as it should once again...
I am very confused as to how the ignition could cause the above described symptoms, but then again I am new to all this. Maybe it is a faulty electrical ignition kit?
Cheers!
 Filesize:  220.86 KB
 Viewed:  1 Time(s)
Date: 7-15-08 01:34
Without knowing which type of electronic ignition system you have, it is difficult to address. Some use a magnetic pickup, others an optical trigger, and some are/were capacitive discharge using the points as a relay. From what you have stated, it appears you had either an optical or magnetic system that replaced the points. Electronic systems should be carefully installed - the wiring is must be exactly correct - and are subject to sudden failure (but then I have had a set of points suddenly break, too - caused me 3 hours of delay in a Kansas roadside park) so be prepared with a spare set of points just in case. what type of electronic system were you trying to use?
'73 2002 "Gretta"
'75 parts car
BMW CCA #19280
Date: 7-16-08 01:42
It was the system from Hot Spark (see the link to their website in one of my previous postings above). I believe that it is a magnetic-type sensor.
I had it installed correctly, according to the manual, and everything worked fine; smooth idle and good behaving through the rpm's. I drove it after installation for about one hour (mostly 90km/h, 55mph) without any problems, had a longer stop, and then again for about 40 minutes on average roads and then when I came to a city (with stops and slow driving) the above stated symptoms appeared, and they would do so everytime after when the engine had gotten warm - thus it performed like normal when it was cool.
Anyway I am glad it is running again, although with the old points put back in, but I am wondering if anyone else had had similar problems with electronic ignition?
