Date: 5-18-08 05:40
Subject: Re: UPDATE
If I didn't know better, I'd say that was a brand new engine. Looks good! You know I wanna be there when you turn the key for the first time! _________________ "It's what you feel, not what you ought to. Reasonable and sensible."
'75 Golf Yellow Automatic 2002 with Weber 32/36 DGAV - "Karl"
Date: 5-21-08 03:00
Subject: Re: UPDATE
it was wrinkle coated, Started it up today and boy oh boy, sounds bloody brilliant. Only a few little things left to do now will probably have it for the weekend! _________________ | zee wrote: | | holy negative camber batman!!! |
tii pistons, 293, 40mm DCOE's, sump baffle approx 150hp
Date: 5-21-08 04:55
Subject: Re: UPDATE
Oh man... that motor looks sweeeeet! _________________
Date: 5-21-08 04:56
Subject: Re: UPDATE
I cant wait to take it out on the track, that will be the best part. _________________ | zee wrote: | | holy negative camber batman!!! |
Date: 5-21-08 06:18
Subject: Re: UPDATE
Hell yeh!
How many k's do you need to run it in for? Its going to be so annoying not being able to explore the upper rev range with those carbs! _________________
Date: 5-22-08 12:25
Subject: Re: UPDATE
well Im gona wait around 3000kms, but that may be a bit too much but I would prefer to be safe than sorry. _________________ | zee wrote: | | holy negative camber batman!!! |
Date: 6-15-08 02:44
Subject: Re: UPDATE
just doing a bit of an update for the blog, car is on the road and has being for the past 3 weeks! Not too many dramas as of yet but I have got a pretty big list of things to do! Major things to do: Rejet carby's, fit vacuum advance, fix heater box, get 5spd box and some bigger wheels. They are the major parts but I also have more future performance mods and hopefully some better body mods! LSD, EFI, BOOST, Suspension work and of course turbo body kit!
When the weather clears up here I will get out and get some decent pics of the car. _________________ | zee wrote: | | holy negative camber batman!!! |
Date: 6-15-08 03:36
Subject: Re: UPDATE
| bingbong wrote: | just doing a bit of an update for the blog, car is on the road and has being for the past 3 weeks! Not too many dramas as of yet but I have got a pretty big list of things to do! Major things to do: Rejet carby's, fit vacuum advance, fix heater box, get 5spd box and some bigger wheels. They are the major parts but I also have more future performance mods and hopefully some better body mods! LSD, EFI, BOOST, Suspension work and of course turbo body kit!
When the weather clears up here I will get out and get some decent pics of the car. |
Does bavariacars have any lsd's hanging around? 320 or 323?
Any details on your turbo plans yet? _________________
Date: 6-15-08 05:24
Subject: Re: UPDATE
They dont have any but they can bring them in from the US, normally they buy a palate of say 5 or so diff's then sell them off. If we can get enough interest around I'm sure I can have a word to Erik about it. As for turbo plans first EFI then I will really start thinking of turbo but as of now, I've got another 2 and a half years before I'm legally allowed it! But EFI with will ITB and then also rework the head, larger valves, double valve springs and a port of course, cant forget the extractors! _________________ | zee wrote: | | holy negative camber batman!!! |
Date: 6-16-08 03:00
Subject: Re: UPDATE
yeah stock gauges! _________________ | zee wrote: | | holy negative camber batman!!! |
Date: 8-6-08 10:12
Subject: Re: UPDATE
Heres a new update, still looking around everywhere for parts and now have a nice 5spd OD gearbox, plus some extractors!
The extractors will probably get a ceramic coat and maybe some of that sexy exhaust wrap stuff, keep the heat down as much in the engine bay.
Now I need to find a 3 pin front half shaft, wont be that easy from what I hear! _________________ | zee wrote: | | holy negative camber batman!!! |
Date: 8-6-08 10:39
Subject: Re: UPDATE
Were those extractors previously on a Qld race car? _________________
Date: 8-6-08 11:04
Subject: Re: UPDATE
Yes I do believe that is true, I picked all these items up from Skippy on this forum. (good guy++) I'm not sure how I will do it yet. May just hit them with a wire wheel as I have a new one waiting to be used! _________________ | zee wrote: | | holy negative camber batman!!! |
Date: 8-6-08 11:26
Subject: Re: UPDATE
aaah yeh, i thought i remembered them. I saw them at RX when i was up in Queensland and Andrew showed me his M2 _________________
Date: 8-6-08 11:46
Subject: Re: UPDATE
next time your in sydney I can show you the car that has no traction in wet! _________________ | zee wrote: | | holy negative camber batman!!! |
Date: 8-31-08 11:44
Subject: Re: UPDATE
I have bolted mine in. They are not direct bolt in, I just cut up some thick steel and drilled holes to bolt through. I bought them from JustJap down south, $500 for the pair. _________________ | zee wrote: | | holy negative camber batman!!! |
Date: 9-1-08 03:48
Subject: Re: UPDATE
Its a fair basic setup, heres a basic computer sketch. Black's the metal, i think its about 7mm thick, braces across the seat for the rails. Red is the rails. simple and easy.
Date: 9-1-08 05:38
Subject: Re: UPDATE
I can see it? _________________ | zee wrote: | | holy negative camber batman!!! |
Date: 9-1-08 11:10
Subject: Re: UPDATE
Where can I get it from? _________________ | zee wrote: | | holy negative camber batman!!! |
