Thread Topic: 70 2002 v3 - m42 - running Threaded
Date: 5-16-08 11:11
Subject: Re: 70 2002 v3 - m42 - running
Cool. Did you have to do any tunnel mods, other than the backet? Also, let us know your success with the electric speedometer. I know a lot of people shy away from installing certain transmissions because of the mechanical vs. electronic speedometer issue.
ClayW
1976 Fjord 2002 Sunroof
Project Blog
Date: 5-16-08 01:05
From: jakeb in Bay City, MI View user's profile Send e-mail
The trans is just a getrag 240, so the same as the 5 speed swap for tunnel mods. I had to cut a little hole at the top to get it higher up in the tunnel. The electric speedo was no issue at all. I have a magnet on the driveshaft and a vdo speedo. I will post some pictures when i get some open time.
jake
70 2002 w/m42
91 318is w/m42
email for 02 and 02tii parts
Date: 5-22-08 03:40
From: Jack in Westborough, MA View user's profile Send e-mail
Cool work on this. I'm very interested in doing a 42/44 conversion. Is there a reason to do a 44 vs a 42? For average driving, what do you think you are getting for mileage on this rig? I would like to have a cleaner burning more economical milage car with about the same motor weight up front so the handling is about the same as the M10. I wold be interested if you get the motor mounts together. Thanks. I'd like to see the photos Andy requested also.
Date: 5-22-08 09:57
I will see what I can do about some pictures this weekend (will be skipping v@v to just relax around the house).
I am not sure on milage just yet. I have a e30 318is with a m42 and it gets around 30.... So I would guess the 02 is higher than that. But normally when I drive the 02 I push it fairly hard.
I am not sure if I like the exhuast yet...it is pretty loud when I really get on it.
The m44 and m42 are very similar. You need to use the e30 oil pan and pick up with the 02(at least the way i did it you do).
The m44 is actually a 1.9L engine and it has knock sensors in the later engine. The m44 also has a serpintine belt rather than 3 V belts (or 1 in my case).
They also run a different intake manifold...
The early m42s had a problem with the profile gasket but by now all should be fixed. The m44 did not have that trouble.
Power wise I wouldn't think there is a big difference between the two engines. I would say if you want to run the DA SC then you want to use the m44 becasue is has knock sensors and DA made their kit for that engine.
70 2002 w/m42
91 318is w/m42
Goto page Previous  1, 2
Page 2 of 2
