Thread Topic: does double valve spring = rocker arm locks in function? Threaded
Date: 5-15-08 08:37
From: mtriple in Northridge View user's profile Send e-mail
Subject: does double valve spring = rocker arm locks in function?
Noob here :) does these two items equal each other or do I need to have both? Is one better than the other? Looks like this is the final part I need for the twin weber conversion.
Thanks
Hamada
E36M3 535im 70Bristol02
Date: 5-15-08 09:53
From: ryanOC in Dana Point, California View user's profile Send e-mail
Subject: Re: does double valve spring = rocker arm locks in function?
double valve springs will allow you to run at higher revs (more) safely. this is to prevent valve float.
rocker locks prevent the rocker arms from moving sideways on the rocker shafts (as opposed to the spring providing minimal force to keep the rockers put)
the rocker locks are relatively inexpensive.
if you decide to get double valve springs you will have to have new (later) valve guides installed in your cylinder head, as 4 of the stock ones are too fat to use with doubles
1969 2002 Automatic w/ Sunroof "pumpkin"
1974 2002tii #2782677 (being assembled)
Date: 5-15-08 10:39
Is your cam stock? Because in that case double springs are not necessary. If your cam approaches 300 degrees you'll need them.
'71 2002ti
'73 3.0CSi
Keep on rolling in the free world!
Date: 5-16-08 08:38
No, completely different function, BUT,
usually used together, as they solve 2 different problems
that can occur at high revs.
Stock revs, stock cam, no problems.
Personally, I like the locks because it makes taking the head apart that
much easier...
Personally, I hate the springs because they're hard to compress.
But you need 'em when you start winding over 6500...
Date: 5-16-08 08:49
Yes I will be dropping a 292 reground. So it looks like you guys suggest I get both for safety measures no problem.
Another quick question: I adjust my valves at home. Would these two items affect the way I adjust the valves? Stock gap?
Thanks guys!
hamada
Date: 5-16-08 09:39
From: JohnC in Sierra Madre, CA View user's profile Send e-mail
Ahmed, neither affects the way you adjust valves. I believe the gap is the same, I use 6 thou on my Ireland 292 regrind, but you should check with Ireland.
John Capoccia
Sierra Madre, CA
'70 Granada megasquirt, 5 spd, 3:91
'74 Golf tii stock
