Thread Topic: SOT: Anyone own/drive an E30 324td or a 524td? Threaded
Date: 5-9-08 06:26
Subject: SOT: Anyone own/drive an E30 324td or a 524td?
I keep compulsively looking up home biodiesel setups and I can't help thinking about having a cheapl-fueled BMW on the side. Has anyone driven or owned one of these?
ClayW
1976 Fjord 2002 Sunroof
Project Blog: http://www.xanga.com/TX02
Date: 5-9-08 06:50
From: Delia in "Don't call it 'Frisco'" View user's profile
Subject: Re: SOT: Anyone own/drive an E30 324td or a 524td?
No, but if it were in THIS car, folks would go nuts trying to buy it from you!
Delia
1973 2002tii
Inka (aka "Orange Julius")
VIN 2762756
1974 2002tii
Polaris (aka "Mae West")
VIN 2782824
BMW CCA member #1974
A-1 Imports Autoworks - San Rafael
www.oldschoolbmw.com
deliawolfe@gmail.com
Date: 5-9-08 07:21
Delia
A wagon? Why?
ClayW
Date: 5-9-08 07:42
'Cuz it's cooler than this alternative:
Delia
1973 2002tii
VIN 2762756
1974 2002tii
VIN 2782824
Date: 5-9-08 07:57
And...you can do THIS with it:
Delia
1973 2002tii
VIN 2762756
1974 2002tii
VIN 2782824
Date: 5-9-08 08:20
Subject: Screw it. I'm going with this:
More room than a Touring.
ClayW
Date: 5-9-08 08:24
Delia
I wouldn't be the first:
Terry Sayther's Sweet E30 Touring:
http://www.terrysaytherauto.com/M3tTurned.html
ClayW
Date: 5-9-08 08:44
I've got an '86 524td and I think pretty highly of it. Beleive it or not it is much more refined than the W123 Mercedes diesels. The power response lets you know that it is still a BMW. And how can you not like the E28 chassis. If you get one just make sure you never let it run hot or the head will pretty much be toast. Also, change the timing belt if you don't know when it's been done last. The engine is a M20 derivative, so a snapped timing belt will have similar results. All in all it's a pretty decent car. However the claims of getting 40mpg+ are pretty outrageous unless you do 55mph across Kansas.
Jay
Date: 5-9-08 11:49
From: BarryA in Fair Oaks CA View user's profile Send e-mail
Subject: Been thinking about the possibility of a 524td in an E21
with biodiesel capability recently - using a 323 M20 front crossmember, the 524td should be a mechanical bolt in. There was a complete E28 524td at the Rancho P&P a year or so ago - kicking myself for not pulling the engine and fuel system.
The E21's fuel tank configuration should work pretty well for a bio/diesel conversion, too - it's actually two tanks, joined by a large-diameter hose that crosses below the driveshaft. Should be pretty easy to split the tanks, using one for regular diesel and one for bio, with fuel pumps & level senders in both, and a heating coil in the bio side connected to the engine's cooling system.
As light as E21's are, I'd think both performance and economy should be pretty good.............
Barry Allen
'69 Sunroof
'82 E21 (daily driver)
'82 633CSi (wife's driver)
'65 El Camino (yard & parts hauler)
Date: 5-9-08 12:38
Subject: Re: Been thinking about the possibility of a 524td in an E21
From the research that I've gathered, if you make biodiesel the right way, you don't need to do the dual tank thing. If you buy certain home biodiesel kits, you don't need to make any modifications to a diesel car, nor do you need to mix the biodiesel with regular diesel.
http://www.homebiodieselkits.com/doihatomaany.html
http://www.homebiodieselkits.com/index.html
As for the M21 swap, I would REALLY like to stick one in a 2002. Power-to-weight would be great and running on home-brewed biodiesel would kick ass.
ClayW
Date: 5-9-08 01:17
Subject: If you're looking for a 524td engine, it's a little known
fact that those engines were installed in Lincolns back when the 524td's were new...Ford only built 1200 or so so they're not easy to find...one of my co-workers had one lurking in her "back 40" but unfortunately it's long gone... Those crankshafts do very well in hot M20 gas engines as they're VERY sturdy...
'69 Nevada sunroof--"Wolfgang"
'73 Sahara sunroof-- "Ludwig"
Date: 5-9-08 01:26
Subject: Yep! 1984-85 Lincoln Continentals.
http://en.wikipedia.org/wiki/BMW_M21
ClayW
Date: 5-9-08 02:25
From: Chris_B in Scotts Valley, CA View user's profile Send e-mail
I owned an '86 524td for 5 years back in the early '90s. Did a lot of work on the motor- Had Dinan engineer an intercooler and cranked up the boost a bit. It had gobs of torque, as expected from a turbo diesel, but overall economy was a bit of a disappointment. I got 28 MPG, hill or dale, stop-and-go or freeway. This is old school technology, with mechanical injection, individual injectors, etc., far from the modern diesels of today. I loved the car, but it smoked quite a bit under a load.
Chris B.
'73 ex-Malaga
Date: 5-10-08 08:09
From: jmon0261 in Chico California View user's profile Send e-mail
Here you go a Lincoln Mark 7
http://chico.craigslist.org/car/675798642.html
Joseph O'Neil
73 02 - Polaris - driver
67 2000 TiLux- Chamonix
