I'll put this here too if someone has any ideas later!!
Hello. Wake up all the engine guru's!
I really need help to solve the low power mystery with my engine. The problem is that torque curve cuts down right after 5000...5500 rpms so the power output is only at about 200hp. I would expect figures like 230...240 from this setup. The earlier engine setup gave a nice flat torque curve from 4000 all the way to 7000 rpms.
Otherwise engine is running well. Compressions are even. Nothing wrong.
I'm asking if people who really have understanding about race engines and/or access to simulation software could point out my problem. Wild guesses are ok too to give some ideas.
I have a .pdf document including all the data about the engine dimensioning with pictures. It was too big to attach here. I will send the pdf to anyone willing to try to help me. Please contact me at tomi.heinonen(at)konecranes.com
Here's some basic info about the engine. And more about the car at my blog thread
http://www.bmw2002faq.com/component/option,com_forum/Itemid,50/page,viewtopic/t,269120/
GOODFELLAS EVOIII engine
JE pistons, 90mm bore
Hemi head 11,8:1 compression ratio
Dr Schrick 39/48 valves
Runners smoothened, valve seats radiused
Tall 146mm rods
Dry sump
Crank std balanced
Cam copy of Dr Schrick 316. With big bearings and base circle like the real thing.
Last engine modifications:
- stock valves changed to Schrick 39/48, seats radiused
- double Dr Schrick valve springs + titanium retainers+ billet rockers
- 45mm webers with 36mm throats replaced by KMS injection system with homemade slide throttle intake
- Crane HI6 ignition replaced by KMS distributorless wasted spark system
Racing is Life - everything before and after is just waiting! "
