I still don't know what specs the motor has. I do know that it was built by Kermit Upton at Mountain Auto Sport Racing in Vt. It has a number stamped on the block and MASR 5/85. Unfortunately Kermit doesn't keep records of that stuff, so he can only speculate about the specs. He says probably around 200HP, but I doubt it. The motor has twin 40 DCOEs, and a nice header. There is an external oil cooler and a new radiator with an electric fan. It has a 245/10 CR 5 speed. That's the one from an early 323. The interior is gutted. There is a welded Kirk cage, and a Kirkey seat with simpson cam lock belts. It came with full VDO gauges, a shift light, a MSD 6AL ignition box, and drilled pedal pads. I need to install a window net, mirrors and a fire system. In the trunk, there is an electric fuel pump and filter. I will need to install a fuel cell eventually. The suspension is pretty basic. IT has Bilstiens, coil overs, camber plates, front and rear stress bars, and bigger sway bars. All new by PO. It also has the Volvo disc brake conversion. All of the rubber pieces need to be replaced with urethane. That is this Winters project. I shreaded the guibo laying a strip in my driveway, so maybe it does have 200 ponies.
134.85 KB |
30 Time(s) |
152.21 KB |
63 Time(s) |
155.45 KB |
16 Time(s) |
138.96 KB |
48 Time(s) |
142.58 KB |
40 Time(s) |
