Date: 5-4-07 12:16
Subject: (nt)
(nt) _________________ '75 e12 Custom
'75 '02 m20
bk_burnout@hotmail.com
Date: 5-4-07 12:44
Subject: Re: My new rear shock tower brace design
Nice job, i like the way you turned the Battery, saves a little room. and the ground connection is good idea, nice touch on the right side.
However i dont think i would buy this particular design. That room you saved is now lost, as the whole area next to battery is now not very accessible, should have just mounted battery in middle.
how about a design that will hold battery, brace towers and still be able to use the area as real trunk space. prefer bolt in type, battery in either corner.
Hope i am not too harsh, but you asked.....
frank _________________ Frank O
1971 2002 Sunroof, daily driver, Recaro SE, Turbines, 5 speed
Date: 5-4-07 05:23
i would hve the battery on the right for weight offset. _________________
email me unkorama@gmail.com
VISA/MC
Date: 5-4-07 06:19
I agree with Blunt. The web should also just have a few holes (large to small) insted of all those little ones all over the place.
Otherwise, nice job.
John _________________ I suggest you sit down and dedicate a couple of hours to this thread. OOPS! NEW LINK! TRY IT NOW
http://forums.vwvortex.com/zerothread?id=2224141&page=1
#1665778
Date: 5-4-07 08:29
I have made them all different ways, with the battery in the middle and off to either side, I build them to the customers rough idea and then make it my own design. Thanks for the input, Brent _________________ '75 e12 Custom
'75 '02 m20
Date: 5-4-07 08:31
This bar can easily be bolted in the way I made it, it just needs a few holes drilled in the ears and the battery tray. _________________ '75 e12 Custom
'75 '02 m20
Date: 5-4-07 08:33
I can build them to anyones specs if they have an idea how they want it. thanks for the input. _________________ '75 e12 Custom
'75 '02 m20
Date: 5-4-07 08:47
Like I said this is a one off for a customer and I can easily change the design, I like to make each one a bit different so everyone has something more unique, since most everyone has the same bar in trunk. I ask about $200 plus or minus about $50 for the bars I build depending on the design, if some people dont want the battery tray or just want a simple bar to go across it would be less, I do all custom fabrication so if you give me a design you want I can build it to you specs for a little more money. _________________ '75 e12 Custom
'75 '02 m20
