Brought the car home, and other than driving it around the block a few times, I ended up parking the car in my garage for the past year. An email response from Mobile Tradition indicating the car was manufactured April 16, 1968 inspired me to get some more work done on her, and to get her back up and running for her 40th birthday coming up 4/16/2008...just around the corner.
Shortly after I got the car, I met up with BarryA from the list, and was given a nice set of E21 non vented calipers, hardlines, and brake pads. Thanks Barry! Just need to actually put em on now....
Went on a few shopping sprees and picked up:
-Kamei style fiberglass front spoiler
-stock front and rear sway bars and hardware (1600 has none)
-side mirror (from Double 02)....still need the gasket if anyone has a spare?
-1600 Badge
-Rear License plate light
-Instrument cluster
-a few beltline trim pieces
-and a bunch of little misc. parts
Picked up a decent front bumper and center grill from a couple FAQers, some mix and match side grills from the Double 02 swap meet in 2005, and some spiffy new roundels from BavAuto. As for the side grills, I couldn't find any affordable all silver grills, but did manage to find a couple straight ones that were spray painted black and had the black anodized covers over part of the slats. A little paint remover took care of the spray paint, carefully prying out the dimple at the underside of the slats allowed me to remove the black slats, and then some adhesive remover and some elbow grease took care of the residue.
For the front bumper, I ended up using the later bumper mounts since my early ones were pretty badly dented. The nice thing about the later ones is that someone welded (or was it factory?) a cross bar on each mount for a place to mount some driving light. Picked up some cheapo 5-1/2" 100W all chrome beauties for $33 online. No worries folks, I'll be sure to run a relay when I actually hook em up! The later mounts proved impossible to mount using the carriage bolt setup used by the early years, so I broke down and ended up drilling thru the frame rail and adding some Cad plated bolts instead. For now I plan on running sans overriders. A couple before and after picts:
Alan
68 1600
96 328i
49.69 KB |
39 Time(s) |
64.1 KB |
36 Time(s) |
