Thread Topic: HORN RELAY QUESTION Threaded
Date: 12-13-05 09:05
From: danjrusdug in Little Rock, AR View user's profile Send e-mail
Subject: HORN RELAY QUESTION
OK, so I finally get the fuel from leaking out of the Kugel pump and decide to drive the car to work. This is the second drive since driving it home from Skip's where the engine was rebuilt. The first drive was to Two Rivers Park outside of Little Rock where I took some pictures. They can be seen here --> http://photoshow.comcast.net/watch/ph6by9PT?sk=6b2048ace7537f0084b6052a8100a5af
I soon find out that my horn ring must be bent because I honk at people when taking a left turn. HOW EMBARRASING ! ! ! !
I don't have my manual at work so I need to know if I disconnect the horn relay, if I will be OK to get the car home where I can fix the horn ring tonight. I've attached a picture as I want to make sure that this is the horn ring.
Thanks in advance.
Doug
'73 Ceylon
'73tii Atlantik
 Filesize:  57.05 KB
 Viewed:  14 Time(s)
Date: 12-13-05 10:10
Subject: Re: HORN RELAY QUESTION
Yes..that's the horn relay...also, I doubt the horn ring is bent. It probably has something to do with the contact that touches the horn ring on the back of the steering wheel...or, if you have an aftermarket wheel, the wire that connects to the horn button may be your problem as well (sometimes these brake and the wire will hit the inside of the hub which is ground making the horn sound)...good luck.
Jeremy
'72 2002Tii - Track Car
