Date: 11-20-05 07:57
Subject: strange problem with a floor jack
I have a big floor jack, i use it to work on my 02, i can raise the car and go to the limit of the jack so it is full of oil.
I cant raise my e36, the jack barely raise it and then the pump feels like it cant handle the extra weight...it goes then pffffff, pfffff like if it pump air.
valve problem?? wrong oil????
I think it is a 5 ton jack...maybe 10 years old.
thanks.
PA _________________ 1976 turbocharged 2002, 14psi, T3, 70%LSD, urethane bush, 36x15 intercooler, 63mm tby,SDS EM4F, 5sp overdrive. Bilsts. Tech edge wb02, datalogger, recaros.
1974 2002 auto (under resto)
Date: 11-21-05 12:53
Subject: Re: strange problem with a floor jack
yeah, it comes from there (costco), it is orange...cheap, but lasted 10years...time for one more _________________ 1976 turbocharged 2002, 14psi, T3, 70%LSD, urethane bush, 36x15 intercooler, 63mm tby,SDS EM4F, 5sp overdrive. Bilsts. Tech edge wb02, datalogger, recaros.
Date: 11-21-05 12:56
i think i had two of them, bot now cannot hold the load. slowly are dropping. so i replaced it with a small costco jack.
they also have a bigger aluminum one for $99. 3 ton.
steve k. _________________ Pre-order you new KGB-Racing Shirt!
Date: 11-21-05 01:52
I remember they gave an extra set of o-ring/seal, if i could find them, i guess its wise to spend few minutes to change them and see...if not i will go with the aluminium one for sure, way lighter !!! _________________ 1976 turbocharged 2002, 14psi, T3, 70%LSD, urethane bush, 36x15 intercooler, 63mm tby,SDS EM4F, 5sp overdrive. Bilsts. Tech edge wb02, datalogger, recaros.
