Thread Topic: My car is still idling rough/ not staying on. Threaded
Date: 10-15-05 11:14
Subject: My car is still idling rough/ not staying on.
Hi all, thanks for all the input I got from you guys on my last post about my car not being able to idle right and stay on. I received some emails from Mike on this forum with some advice and I think I found the problem, thanks Mike! I've been messing around with it alot and tried cleaning every little part on/in the carb, everything seemed to be good. I was pretty sure this behavior had to do with a vacuum problem, there is no resistance when I suck or blow on the vacuum hose hooked up to the dizzy while the car is on/off. So my question is... will a vacuum advance unit from a 320i dizzy work on the 2002 dizzy? If so, which years, any chance one from an 81 320i will work? Where would I be able to find the vac. advance unit for the 2002 if the 320i ones wont work?
Thanks again,
-Cyrus
