I will be running all urethane bushings, Bilstein Sports, Eibach lowering springs, 22mm sway bar(solid) with urethane links and mounting bushings, with 15x6 wheels with 34mm offset. Tires will be 195.60R15.
Too harsh for street?...its not a dily driver, but will be driven quite frequently....weather permitting.
TIA 02MonsterMike
Date: 10-14-05 11:19 From: billwilliams Subject: Monsters drive that set up on the street, so you da man
Say hello to hemmoroids and arms of steel...guns
Date: 10-14-05 12:33 From: m3pedro Subject: Mine is harser than that, you should be okay. But it will be stiff.(nt)
Date: 10-14-05 12:43 From: RayC911 Subject: Use Stock rubber bushings at least. I have the same set-up you are
talking about except i'm using IR 275lb stage II springs and rubber bushings. If you're not going to commute and use it as a daily, it should be fine. The handling offsets the stiffer ride for me.
