Date: 10-14-05 08:31
Subject: chassis# 1668997 was it produced before 2/69 or after 3/69????
Does anyone know how to tell? I need to get new front pads and rotors and there is a split for the pads. I need to know which ones to buy but cant figure out the production date of my 1969 2002 VIN 1668997.
Thanks again. (the fog has lifted!)
Date: 10-14-05 08:38
Subject: I know I have three bleed nipples and two (i think) brake lines.....
going to each caliper. I think they are dual piston. This should be the newer caliper correct?
Thanks for the advice!
Subject: Should be after, my VIN is 1666777 and was manufactured
in June 1969 if I recall correctly.
Date: 10-14-05 08:46
Subject: thank you!!(nt)
Date: 10-14-05 09:38
Subject: Unless there's another split between two different 4 piston caliper
designs in early calendar 1969 production, the primary split should actually come at the end of December 1969 @ chassis # 1664760 - that's the division point between what is sometimes referred to as "series I" and "series II" production within the 1969 model year.
Series I cars had painted grill slats, long neck diffs, sliding center drive shafts, and single circuit/2 piston front calipers and were built before 12/31/68; series II cars had all the later stuff and were built after 1/1/69.
Date: 10-14-05 09:47
Subject: Re: chassis# 1668997 was it produced before 2/69 or after 3/69????
Date: 10-14-05 10:01
Subject: That explains it very well Barry. I have the later calipers!!(nt)
Date: 10-14-05 11:12
Subject: That's a fairly late '69...mine is 1664801 and was assembled in Feb...
and uses four piston calipers. The VIN break between two and four piston calipers is 1664761 (give or take a few #s). I've never been able to figure out why most parts books show different pads before and after 3-69. My 69 and 73 use identical brake pads. However, the two piston calipers use different pads from the four piston ones.
Date: 10-14-05 11:59
Date: 10-14-05 12:42
Subject: Unless there's some variation in the early 4 pot calipers, the correct
split between early and late model year 1969 cars should come at chassis # 1664760 - the two versions are sometimes refered to series I (early) and series II (late).
Series I cars were built up to 12/31/68 and had 2 pot single circuit front brakes, painted grill slats, long neck diff's and sliding center driveshafts; Series II cars were built after 1/1/69 and had all the later stuff.
Date: 10-14-05 12:43
Date: 10-14-05 12:50
Subject: Sorry about the multiple posts - am getting an error message followed
by the message posting twice.....
