Thread Topic: Driver's side window stuck down Threaded
Date: 10-14-05 09:23
Subject: Driver's side window stuck down
My 2002 developed a new feature this morning...
The driver's side window doesn't want to roll up. The handle just spins and spins. How do I get in there to fix this.
~Vroomer
Date: 10-14-05 09:51
Subject: I'd check to see if the handle is stripped out first....if not email
me and I can help explain it, I've done it many times...steve
Date: 10-14-05 11:10
Subject: Agree with Steve--suspect one of the pivots has worn out, or
the shaft that the window crank is fastened to has stripped from the drive gear that moves the window. While the pivot pins are available as a M-B part, you have to fabricate a new shaft by grinding/filing a bolt; if that's the problem drop me an e-mail and I'll send instructions.
Date: 10-14-05 12:00
Subject: Pics here.
Took the handle off. Looks like there's teeth that catch.
~Vroomer
