can you adapt the bosch 009 mech advance distributor of an air cooled vw to an '02? i think you have to change the shaft to the bmw's gear type? btw they are half the price of a new 008/002 bosch for '02's
Date: 10-13-05 09:53 From: Jake P Subject: keep in mind #3 is retarded
to keep the heat down. #3 cylinder in a VW air cooled engine has a habit of burning valves
Date: 10-14-05 08:16 From: delk Subject: Re: keep in mind #3 is retarded
The only way I could see that happening is with the cap. you should be able to fit a standard '02 cap on there right?
Date: 10-14-05 09:58 From: Arizona 02 Subject: Retarded by a smaller #3 lobe on the shaft to open points.(nt)
Date: 10-14-05 10:15 From: Jake P Subject: Re: You're retarded!
the VW dist. has an offset key where it installs to the dist. drive. Therefore she only fits in 1 way, this allows them to machine #3 lobe at an offset. Why not take a stock dist and convert it over to a fully mechanical advance
